i have some small problems.
lefjomp
i use blackhole 2.0.9 with the latest update installed.
the problems i have is.
1. when i try to restart the enigma it often wont restart, it just hangs itself, and i have
to manually use the switch at the back.
2. often i get the aspect ratio wrong, let say that i have watched a Movie from my harddrive, when i switch back to the ordinary channels i get the wrong aspect ration, and i have to manually switch on and of the letterbox mode, after that is done it works good again.
3. and the last question is: i also have an older topic about this, but the tread is dead, so i ask again.
why dont the receiver switch back to 50 Hz after watching a movie in 60Hz? it is set to 50Hz but the tv shows 60Hz, so i once again have to manually switch from 50 to 60 and back to 50 and it works just great after that.
i hope that someone will help me with these issues.
i really like the blackhole image exept these problems.
I do restart sometimes twenty times a day and I do not have that problem.
I use Fixed 50 Hz EU TV standard also no problem.
You have test with clean image .No addons and plugins ?
yes i have tested a Clean image but same problem, you mean that you need to restart the box about 20 times per day?
No,
when I working on my skins
I have to restart image a hundred times.
Install a clean image with only the default plugins/addons enabled.
Add your add-ons one at a time
And slowly Test until you find the cause of your problem.
