I need a VPN plug-in for Ultimo 4k
MohamedOpera
Hello there,
I would like to know your recommendations about a VPN plug-in for my ultimo 4k .... if there is a free one it will be great...
thanks in advance
Well, the one already embedded in the black hole images is always says stopped and when I try to make it start with the green button it never go on
And when I try the open vpn from the dreamosat script all of the servers are not working most of the time
Like Shiro is saying check your configs
Lots of info here to read about configuration:
https://openvpn.net/community-resources/how-to/
Sure from LOG you can understand the issue
ciao
g.
Well, thanks for the replies guys, but unfortunately and after reading the link u shared above I guess the problem is in my connection not in the software
I could not even opened the link u shared on my laptop without a vpn tool
I am currently in Dubai UAE and I guess they are blocking the open VPN website and servers, so I do not think there is anything we can do here unless I leave UAE or get other software or workaround
Thanks anyways and hope if we can find other way as I am stuck here for a while
well, i managed to setup my VPN account on openvpn but on different image not BH, and it says running, but after all again the problem seems to be in UAE in general, as all the vps servers did not worked and when i contacted the VPN service provider they said its a nation wide issue in UAE and offered me a refund
so anyways, thanks guys for the support
What VPN provider do you use?
I found this recommendations for UAE
https://www.bestvpn.com/vpn-comparison/best-vpns-for-uae/
