i need advice.... Do i replace my vu+ultimo
rainbowlibya
hi all of you guys
i need advice... Do i need to replace my vu+ultimo to the new one vu+duo2 or solo2 for new features
i know The difference in the cpu and ram My question here.. Is it worth it to pay a lot of money for Change... or stay on my ultimo waiting for answer
s
hi all of you guys
s
There's only really need if you require transcoding features tbh for streaming. Change it when its knackered .... There may even be an ultimo2 by then with ultra HD ?
The answer is only inside you.
Nobody can know the use you make of your box.
If you want the better performances and the better machine on the market with nice gadgets like lcd color screen go for duo2.
If you are happy with your ultimo and you want to try something new you can have a totally new experience with PrismCube and Xbmc.
