i need help for installing wireless usb wifi
eagle2005
dear guyse
i have a problem with installing the usb wifi on m vu+uno
the type of the wifi usb is mini tplink 723 v 2.2 the image is black hole 1.7.6
the problem is ::::
i have instaaled the device correct as i think cause when i made the network test everything is ok and made it as a defult conection but its work for a while and suddunly disconnect with out any action from me
i dont know is somthing should i do for installtion process i did not do?????????????????
thanks in advance
