I need to disable autoscan. How?
dvbtshop
Is there possible to disable autoscan? I'd like to "lock" /etc/enigma2/lamedb, which I prepare (e.g. erase some channels I don't want to see in global channel list), but BlackHole software again and again updates it (without I tune it again, naturally). OpenPLI image supports (and respects) a special flag "disable channel autoscan", but it's quite poor and has other disadvantages :-(. Why don't BlackHole guys support this small (but helpful) thing?
If it's so hard to add it, I ask. I'm not Linux newbie, so I don't need end user level support, and I can do a telnet and/or ftp patch/hack of something. Can I do something for (against, in fact) it any way? And what? Thank you very much.
BlackHole images are based on official Vu+ source code. Report your needs to Vu+ directly to add this function: www.vuplus.com
If you have some patches and/or URLs with patches, post them to Vu+ Support team (see the URL posted above).
was there any progress on this issue.
it's a pitty that lamedb is regenerated every time.
I did not know about autoscan but I can't understand why if I delete a channel from the database the box decides to create it again.
Regards.
