I need to reflash bh on vu+duo2 but its already on it
beef
Hey people ,
ive got a problem , long story short i deleted some-files i need and made a few wrong steps and so i was told to start again and re flash my box .
so my box already has bh on it , I need to do a fresh install but when i put in usb with image it does load .
do i need to delete files from the hdd in the box ? via FTP ?
:welcome:
Make sure you don't have a back up on ur hard drive. You could disconnect the hard drive and do a clean install. Also re download the image you going to use as it maybe corrupt.
So I should just deleate everything that's on the HdD on the receiver. Then install USB with image and continue as usal .
No, you don't have to delete nothing from HDD. Just disconnect it (internal Sata connector) or simplier way is to only rename (if it's present on HDD root) folder /vuplus to for example /vuplus_bck.
Disconnect all your USB devices too, except USB key with a new image.
This
