i want to upgrade to 2.0.2
hi guys,
posting here instead of opening a new thread.
I'm currently on a Vix 2.4 and would like to install the latest BH. Any intermediary steps/images or can I go ahead?
I would flash the bootloader and then you can flash the latest BH.
I´m not sure if you have already flashed the bootloader?!
If your image based on the driver 13.12.2011 OE 1.6 or older, then you need the bootloader.
If you are not sure, then I would flash the bootloader a second time. That´s no problem.
Hello , I've the same problem here : I followed the instructions but everytime i fail to updgrade the STB "Solo" , When i power the receivre on , the LED switch to the green after and the box start normally ! is there anything i missed while the upgrade ?
Thank you
