iDreamX for Mac OS X
Mito
ToolooSoft
iDreamX
The Swiss Knife for Enigma1 & Enigma2 Sat- & Cable Boxes.
With iDreamX you can edit your favorite lists (bouquets), read and search the EPG (Elektronic Program Guide), set and edit timer events, watch tv or hear radio on your Mac, iPhone, iPad, Android, Symbian and much more.​
iDreamX is a Mac OSX application and works with: all Dreamboxes (except DB100), VU+ (solo & duo), Kathrein with Enigma2, Topfield with Enigma2 and more....​
Features
• Supports all Setup boxes with Enigma1 & Enigma2​
(Dreambox, VU+, Kathrein, Dbox2, Topfield e.t.c.)​
• Automatic detection of the operating system​
• Manage unlimited number of boxes​
Bouquet Editor
• Create Bouquets​
• Editing the bouquet (add, delete and sort of channels)​
• Rename the bouquets​
• Sorting the bouquets​
• Delete bouquets​
• Channel Search​
• Save & load the bouquets on Mac hard drive​
• Full support of channel markers​
- Create​
- Move​
- Rename​
- Delete​
• Import bouquets (add bouquets from saved settings)​
• Automatically remove deleted channels in all bouquets​
FTP client
• Navigate with mouse and / or keyboard​
• Upload (also with drag and drop)​
• Download (also with drag and drop)​
• Create folder​
• Create text file​
• Create sym link​
• Move File/Folder​
• Stream any music or movie file to VLC​
• Play any music or movie file on the box.​
• Edit text file (integrated Linux text editor)​
• Rename files, folders or sym links​
• Duplicate file​
• Change permissions​
• Delete files, folders or sym links​
• Search​
• Define a folder as movie location​
Telnet Client
• Built-in Telnet client with automatic login​
• Executed commands can be called again with the cursor keys​
• Telnet fast menu​
• Save telnet protocol as text file​
EPG
• Show any EPG​
• Multi EPG​
• Set Timer Event​
• Search (globally with enigma2 boxes)​
• IMDb support (The Internet Movie Database)​
Box Timer
• Box-Timer list​
• Box-Create Timer Event​
• Box-Edit Timer Event​
• Box-Delete Timer Event​
• Box-Clean the timer list (Remove old events)​
Mac-Timer
• Mac-Timer list​
• Mac-Create Timer Event​
• Mac-Edit Timer Event​
• Mac-Delete Timer Event​
• Mac-Clean the timer list (Remove old events)​
Control
• Built-in software remote control (Dreambox, VU+, Kathrein)​
• Dream-Keyboard Emulation​
• Standby​
• Wake Up​
• Restart Enigma​
• Reboot Box​
• Deep Sleep​
• Record​
Screenshot
• Screenshot​
• Screenshot incl. OSD​
• OSD-Shot​
• LCD-shot (Enigma1 only)​
• Save Screenshot​
• Export Screenshot​
• Copy Screenshot to Clipboard​
• Automatic screenshots when using SW - Remote​
Teletext
• Showing and using Dreambox Teletext (enigma1 only)​
Timeshift
• Save current timeshift file to a movie folder (enigma2 only)​
Plugins
• Easy plugin install (enigma2 only)​
Sat-Finder
• Display SNR, AGC, BER​
(Helps to adjust the satellite dish)​
Message
• send messages to the dreambox​
• Adjustable Display Time​
• Yes / No question to Dreambox. Answer will appear in iDreamX (enigma2 only)​
Movie
• Display the Movie List​
• Change the Movie Location (enigma2 only)​
• Add Movie Location (enigma2 only)​
• Remove Movie Location (enigma2 only)​
• Search​
• Delete Movie​
• Movie Download​
• Rename movie​
• Stream Movie to VLC​
Streaming
• Display the content from current channel​
• Select all currently running programs contents​
• Stream current channel to VLC​
(Automatic Fullscreen mode possible)​
• Stream any channel without switching the box (only enigma2)​
• Record current channel to Mac hard drive​
• Record any channel without switching the box (only enigma2)​
• Time shifting (time shift) is possible​
• direct channel switching with bouquets​
(including subchannels)​
Web Interface
Control iDreamX with a Web Browser. (Also via Internet)​
• Access http or https (ssl)​
• Password protected.​
• Web TV - Stream tv-channels​
• Web Radio - Stream radio-channels.​
• Web Movie - Stream movies from box harddrive (coming soon)​
• Stream Setup -Stream adjustment (A/V bitrate, video size e.t.c.)​
• Box Control (Standby, Restart Enigma, Reboot Box and Deep Sleep)​
Mobile Web Interface
Control iDreamX with a iPhone, iPad, iPod Touch, Android-, Symbian-Device zu bedienen (Also via Internet)​
• Http access​
• Passwort protected.​
• TV - Stream tv-channels​
• Radio - Stream radio-channels.​
• Movie - Stream movies from box harddrive​
• File - Stream movies or audio files from the Mac harddrive (subtitles support)​
• iSight - Stream Mac-iSight (Webcam)​
• Screen - Stream Mac-Screen.​
• Stream Setup - Adjust network stream (bitrates video size e.t.c.)​
• Box Control (Standby, Restart Enigma, Reboot Box und Deep Sleep)​
• Message - Send message to the box (Yes/No question support)​
Streaming needs "VLC Media Player" version 1.1.1 or newer
(Use VLC v1.1.9 if you are running Leopard)
  • iDreamX v2.7.0b.zip
Dani
Yes, great tool.... has work perfectly for me on Vu+ Ultimo
very nice streaming....
Not many tools for Mac, but this seems to handle most things you need to do :)
Have used it for a DM800 for a quite a while, but would say it works even better with the Vu+
perise
New version available, it's a beta version but works great! New features:
Picon-Tool, Bootlogo-Tool, Movie-Convertion-Tool and many more...
Dani
Strange, i have been using Version 4 for the passed 3 months...
Had Version 3 before that....
Basil
Got a macbook to play with.
I downloaded iDreamX and can't find a way to delete some sats and some channels just like I do with dreamset on my pc..any idea?
Thanks
Sent from my GT-I9100 using Tapatalk 2
Mito
@Dani,where have you downloaded iDreamX vesion 4 or 5 mate,can you post link or upload it somwhere??
Thanks in advance and all best.
You can download iDreamx latest version from:
http://software.tooloo.de/tooloosoft/beta_version.html
@MujaG@
BH Lover
@Mito,
thanks mate,i have found only 3.05 version and 3.10-beta,but i think @dany was tallking about version 4-5???So,im little bet confused about that.
Thanks again mate and cheers
Mito
@Mito,
As fare as I know, the last beta version available is 3.0.10.
I think Dani was talking about 3.0.4 ... 3.0.5 ;)
