hi I have a vu plus duo version 2.3 2010 which is written on motherboard,I have found most images I have tried making box slow to load,the only one that seams ok is openpi and satdreamgr image.is this comen with these boxes or just mine,any advice on this please.
Hi,I have flashed box with usb but have not used meoboot before is there any info or help how to do this and can you explain the clear memory plug or free ram script don't understand that bit thanksYes,,,but I recommend , to put pure BH image on the Flash and then install meoboot (@USB) and install BH again on the USB as an extended flash memory.
letter on use a the clear memory plug in or a Free-Ram script and use it at least once a day!
You try format this second usb and next mounth in manager ? to other desctination from this first .Hi,I am running blackhole image on meoboot,and all is ok for now,I am trying to use second usb to load picons and epg but it won't mount as media/usb,I don't understand any help on this please
In my box im used like this:Hi yes the first usb is mount in meoboot,the only mount on second usb is /media/downloads works but how do I install picons and peg on this or can I install picons on media/hdd
