Request IMDB plugin fix
Palinkat
Hi All,
Does anyone have a fix for the IMDB plugin. It's been broken for a while. Probably similar issue to Mytube (url change).
Thanks!
Unfortunately the Advanced Movie Selection plug-in does not work for live broadcasts. So if there is a movie being relayed on a channel, I cannot figure out the ratings. It's a pity that till now no fix has been found for the IMDB plugin.
movie-info-screen-png.10235
Currently I'm working on implementation of searching data from IMDB in the Filmweb Plugin (plugin screen above):
http://code.google.com/p/enigma2-plugin-extensions-filmweb/wiki/Welcome
Currently this plugin is searching data in filmweb.pl portal, but in the version 1.2 it will be possible to change searching engine to the IMDB and scraping data from IMDB portal instead of filmweb.
Regards
I've prepared the first release of the Filmweb plugin with the functionality of scrapping data from IMDB. Version is available on:
Admin Edit, please code links
zrzut-ekranu-2013-02-15-o-02-37-12-png.10245
zrzut-ekranu-2013-02-15-o-02-28-02-png.10244
can you upload this file here please? I'm sure that will help everyone instead of checking external links, which (BTW) are not allowed in here. Thanks
edit: it's not showing in plugin menu after install; long pressing blue either
image 1.7.9-3
