Impossible to get Unicable configuration to work with FBC
Lupusz
I'm using a "DUR-line DCS 552-16" connected directly to the vu+ uno4kse with 2x DVB-S/S2. The cable is connected to the left connector seen from the back.
It is impossible to connect the tuner cascaded: A, B-> A, C->B, D->C, ... as I connections can only be chosen for all tuners to tuner A or B, also for the FBC virtual tuners.
When I connect Tuner B with Tuner A, at least this tuner works.
C to G is not working at all. E.g. if I use the tuner C connected to A doesn't work and connected to tuner B doesn't work.
I even tryed to use a configuration from another image, which works fine with cascaded tuner from A to G.
Doesn't work either and when I enter the tunerconfigurations, it is overwritten with connections to tuner A or B.
Here is the config where I had to connect everything to Tuner A (tuner 0) of Tuner B( tuner 1) - I chose Tuner A (tuner=0), but unsucessfully also tryed Tuner B (tuner 1):
config.Nims.0.advanced.lnb.1.format=jess
config.Nims.0.advanced.lnb.1.lof=unicable
config.Nims.0.advanced.lnb.1.scrfrequency=975
config.Nims.0.advanced.lnb.1.scrList=1
config.Nims.0.advanced.lnb.1.unicable=unicable_user
config.Nims.0.advanced.sat.192.lnb=1
config.Nims.0.configMode=advanced
config.Nims.1.advanced.lnb.1.format=jess
config.Nims.1.advanced.lnb.1.lof=unicable
config.Nims.1.advanced.lnb.1.scrfrequency=1025
config.Nims.1.advanced.lnb.1.scrList=2
config.Nims.1.advanced.sat.192.lnb=1
config.Nims.1.advanced.unicableconnected=True
config.Nims.1.advanced.unicableconnectedTo=0
config.Nims.1.configMode=advanced
config.Nims.2.advanced.lnb.1.format=jess
config.Nims.2.advanced.lnb.1.lof=unicable
config.Nims.2.advanced.lnb.1.scrfrequency=1075
config.Nims.2.advanced.lnb.1.scrList=3
config.Nims.2.advanced.sat.192.lnb=1
config.Nims.2.advanced.sats=192
config.Nims.2.advanced.unicableconnected=True
config.Nims.2.advanced.unicableconnectedTo=0
config.Nims.2.configMode=advanced
config.Nims.3.advanced.lnb.1.format=jess
config.Nims.3.advanced.lnb.1.lof=unicable
config.Nims.3.advanced.lnb.1.scrfrequency=1125
config.Nims.3.advanced.lnb.1.scrList=4
config.Nims.3.advanced.sat.192.lnb=1
config.Nims.3.advanced.sats=192
config.Nims.3.advanced.unicableconnected=True
config.Nims.3.advanced.unicableconnectedTo=0
config.Nims.3.configMode=advanced
config.Nims.4.advanced.lnb.1.format=jess
config.Nims.4.advanced.lnb.1.lof=unicable
config.Nims.4.advanced.lnb.1.scrfrequency=1175
config.Nims.4.advanced.lnb.1.scrList=5
config.Nims.4.advanced.sat.194.lnb=1
config.Nims.4.advanced.sats=194
config.Nims.4.advanced.unicableconnected=True
config.Nims.4.advanced.unicableconnectedTo=0
config.Nims.4.configMode=advanced
config.Nims.5.advanced.lnb.1.format=jess
config.Nims.5.advanced.lnb.1.lof=unicable
config.Nims.5.advanced.lnb.1.scrfrequency=1225
config.Nims.5.advanced.lnb.1.scrList=6
config.Nims.5.advanced.sat.194.lnb=1
config.Nims.5.advanced.sats=194
config.Nims.5.advanced.unicableconnected=True
config.Nims.5.advanced.unicableconnectedTo=0
config.Nims.5.configMode=advanced
config.Nims.6.advanced.lnb.1.format=jess
config.Nims.6.advanced.lnb.1.lof=unicable
config.Nims.6.advanced.lnb.1.scrfrequency=1275
config.Nims.6.advanced.lnb.1.scrList=7
config.Nims.6.advanced.sat.194.lnb=1
config.Nims.6.advanced.sats=194
config.Nims.6.advanced.unicableconnected=True
config.Nims.6.advanced.unicableconnectedTo=0
config.Nims.6.configMode=advanced
config.Nims.7.advanced.lnb.1.format=jess
config.Nims.7.advanced.lnb.1.lof=unicable
config.Nims.7.advanced.lnb.1.scrfrequency=1325
config.Nims.7.advanced.lnb.1.scrList=8
config.Nims.7.advanced.sat.194.lnb=1
config.Nims.7.advanced.sats=194
config.Nims.7.advanced.unicableconnected=True
config.Nims.7.advanced.unicableconnectedTo=0
config.Nims.7.configMode=advanced
Could someone please help me to find the right tuner configuration for the vu+ uno4kSE wit 2x DVB-S/S2 and openBH 5.1?
Cheers,
Lupusz
