Inadyn ??
SANTANA1962
Hello great team,
Need your kind help to explain what is Inadyn and how to use it ?
I have Uno with BH 1.7.4 .
Alllllllllllllllllllllllllllll the best .
Google search is your friend
INADYN is a free DynDNS client. It gives the possibility to have your own fixed hostname registered on the internet, although your IP might be changing. It checks periodically whether the IP address stored by the DNS server is the real current IP address of the machine that is running INADYN.
If you are using Inadyn
You can if you do not have this feature in your router
Use Inadyn in the image.
You must be a registered user
on one of the following services.
