S saxog Vu+ Newbie Dec 28, 2015 #1 Hi, The maximum time of info bar displaying time can by default limits only be setled at 10sec. How can I increase that limit? Thanks a lot
nunigaia Moderator Dec 28, 2015 #2 saxog said: Hi, The maximum time of info bar displaying time can by default limits only be setled at 10sec. How can I increase that limit? Thanks a lot Click to expand... Change it to " no timeout ", it will be allways present ... to hide press <OK> twice if you have setted to show second infobar. best regards nunigaia
S saxog Vu+ Newbie Dec 28, 2015 #3 Thanks nunigaia!, it is an option. Somewehre I have read about some busybox command lines which increases the limit..., dont remember where, it would be the better option for me.
