info streaming mkv file
evilangel004
hi
I have a nas with the mkv file and would like to see them streaming on my vu duo with Black Hole 2.0.9. which addons I use to watch streaming movies? I used media player and vlc but I could not see the folders with files, there is a guide to set it up?
i have press 2 x blue button and use the last option in Blue Panel and mount your NAS share
i see nas but i can't enter to see folder i receve an error
hi
First of all, go to into Blue Panel (2 x blue button) and use the last option to setup a connection to your NAS (CIFS and NFS are both supported according to your hardware and NAS configuration).
After this step, you can use Media Player (NO VLC) to browse your NAS share.
ok i try it , thanks for reply! Regards
these is how i see network browsing
url]
