AlexWilMac
Moderator
BH is a great work, no doubts about that.
Still, some improvements to get it more comfortable is always possible.
Once is surely, in my opinion, the Infobar behaviour.
Every box or decoder or software I've used so far has, among their settings, the chance to set how many seconds the user likes to keep infos (channel, program name, etc.) shown: this is normal and it's right.
What it's not normal and I find very uncomfortable, is that if the users want to keep manually visible the infobar as long as they like, it is not possible with BH because it always uses the timer setting in the preferences.
Every other box or decoder I've used, instead, even the cheapest ones, in case of manual intervention of the user (for instance pressing OK or Info) shows the infobar and then waits for another press of the same key whilst the timer is valid only when the user is zapping from a channel to another.
This would be an important improvement, I think.
