installation problems [Solved]
noizer
This afteroon I tried and autoupdate from 3.0.0 on my solo se and I ended with a dead boot. So I tried to reinstall my image. I have tried to install the new images from usb without success. When I connect the usb the light flashes 3 or 4 times rapidly and then begins to fade and light slowly, like when it finishes the update. It's like is not loading the files correctly from the USB. I have tried 4 different USB , including one that I used to the previous install.
I have a mac and I have tried to format the usb drives with MBR and FAT.
Anyone can help?
