installing vu+ solo2
Mark Speedie
Sorry for stupid question,but trying to install brand new vu+ solo2 box,have existing sky satellite dish,just want to make sure you don't need motorised dish,as you can gather I'm a newbie,only picking up limited channels
Using your receiver for a fixed dish setup, on 28.2E, is a bit of a waste, but it's very easy to do.
Go into the menu, Service searching, and select tuner A, or B, depending where you have connected your coax cable.
Set the configuration mode to simple, using the left/right arrow buttons, then set the Mode option to Single, and satellite to Astra 2, 28.2E.
Once done exit, and use the System Searching, and scanning option, to scan in your channels, Automatic, to let it scan all of them in itself, or manually to add the channels you want.
