smogmonster
I am looking at buying either a solo 4k or the uno 4k. I am not bothered about the solo's miniature display, so the only significant difference that I can see is the option to mount an internal hard disc on the solo 4k.
I have been told an internal hard drive is preferable as a usb drive puts more strain on the processor. Can anyone advise as to how far this is true?
All things being equal I would go with the cheaper uno 4k, but if that meant I could record fewer channels simultaneously, then it worth spending a little more.
However does not the newer uno 4k have a faster pprocessor (1700 mhz dual core as opposed to 1500 mhz). Would that not compensate for recording via usb anyway?
Can anyone advise? Thanks.
