Internet problem at open bh
saeed t
Hello. Even in the last update, after shutting down the vu ultimo 4k device completely, unfortunately, the internet connection is unavailable on the internet, either in LAN or Wi-Fi. And until the network is restarted, the Internet will not connect. Please correct this problem. Fix it.
All this is done, I even changed the router, but the problem still exists. It should be noted that the problem is with the image and seen in other users.
Once more and the last time.
The problem is with you
I think not the router, but the Internet connection you are using,probably restriction in your country.
I think you know what I mean.
Why are you nervous?!!! It has nothing to do with restrictions
Well because I have the same image and the same box.
You constantly repeats the same question, and there is no problem.
No problems with internet connection.
The same holds for dozens of our beta testers.
No one has any problems with internet connection.
What does that mean?
How I saw it
You do not have a direct connection from your country ?
You connecting through servers in other countries ?
Maybe that's a problem ?
How I saw it
Thank you very much for your help and patience. Dear dear, we always remind you of Nikki and we lived with your beautiful skins if you could put Skin MX X7 on your panel and upgrade it.
