IP CAM VIEW
ObiWan
Vip
Hi
is there some plugin to viev an IP CAM ?
I've searched around the net but I've only found old stuff
Thank
Hi
Thank
Try look to feed im no remember now name this plugib but i think is on feed becuse im in past test this plugin
I use Webcamviewer and I am happy with it.
To get it : Menu -> Plugins -> red Button -> multimedia section -> webcamviewer.
You can add your ip cam in the xml file located into the plugin folder, which is at :
/usr/lib/enigma2/python/plugins/extensions/webcamviewer
Hi
thanks for your answer: I' ve installed webcamviewer but I got problems.
I've edited the cfg file adding thisfew rows
<cam>
<name>MY IP CAM</name>
<url>http://admin@192.168.10.51:99/mobile.htm</url>
</cam>
Now I can see the choice in menu but when I select it simply the screen become darker
and nothing happens....
My IPCAM has 3 ways to work:
1) ActiveX Mode (For IE Browser)
2) Server Push Mode (For FireFox, Google Browser)
3) Snap Motion Mode (For CellPhone Browser)
I'm using the metodh #3 .....
Thanks
cu
There is another plugin called camoFS which is updated constantly, not used it myself but you will find it easily searching in google.
Hi, I've found it in plugin list of bh oe2.1 but gices an error during installation, any idea ??
I doubt the url you put in the xml file can work.....
thanks .. but why ??? The syntax is ok and works an all browser
cu​
