kondor
Hi
A lots of iptv crash..
here is log:
here is log:
OpenBh Enigma2 Crashlog
Crashdate = Sa Apr 7 05:35:54 2018
Creator = OpenBH
Version = 4.1
Build = 024
Type = release
Machine = vuduo2
URL = http://www.vuplus-community.net
Compiled = Mar 26 2018
Skin = BlackShadowSE_P/skin.xml
Component = Enigma2
Kernel CMDline = libata.force=1:1.5Gbps bmem=192M@64M bmem=384M@512M memc1=788M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
Nim Sockets = NIM Socket 0:
Type: DVB-S2
Name: Vuplus DVB-S NIM(AVL6211)
Frontend_Device: 0
I2C_Device: 2
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
I2C_Device: 3
/demux8
< 678.058> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 678.058> [eEPGCache] next update in 2 sec
< 678.058> [eDVBServicePMTHandler] ok ... now we start!!
< 678.058> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 678.059> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 678.059> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 678.064> [Notifications] RemovePopup, id = ZapError
< 678.096> [eDVBServicePlay] timeshift
< 678.175> [eHttpStream] openUrl: redirecting to: xxx
< 678.280> [eHttpStream] Thread end connection
< 678.307> [eFilePushThread] wait for driver eof timeout
< 678.328> [eInputDeviceInit] 0 160 1
< 678.331> [InfoBarGenerics] KEY: 352 OK
< 678.343> [eDVBServicePMTHandler] PATready
< 678.343> [eDVBServicePMTHandler] use single pat entry!
< 678.343> [eDVBServicePMTHandler] use pmtpid 1000 for service_id 0001
< 678.343> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 678.343> [eDVBSectionReader] DMX_SET_FILTER pid=4096
< 678.344> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 678.344> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 678.345> [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
< 678.346> [eDVBServicePlay] have 1 video stream(s) (0100), and 1 audio stream(s) (0101), and the pcr pid is 0100, and the text pid is ffffffff
< 678.351> [eTSMPEGDecoder] decoder state: play, vpid=0100, apid=0101
< 678.355> [eDVBAudio0] DMX_SET_PES_FILTER pid=0x0101 ok
< 678.355> [eDVBAudio0] DEMUX_START ok
< 678.355> [eDVBAudio0] AUDIO_SET_BYPASS bypass=1 ok
< 678.361> [eDVBAudio0] AUDIO_PAUSE ok
< 678.363> [eDVBAudio0] AUDIO_PLAY ok
< 678.369> [eDVBVideo] Video Device: /dev/dvb/adapter0/video0
< 678.369> [eDVBVideo] demux device: /dev/dvb/adapter0/demux8
< 678.372> [eDVBVideo0] VIDEO_SET_STREAMTYPE 1 - ok
< 678.376> [eDVBVideo0] DMX_SET_PES_FILTER pid=0x0100 ok
< 678.376> [eDVBVideo0] DEMUX_START ok
< 678.376> [eDVBVideo0] VIDEO_FREEZE ok
< 678.379> [eDVBVideo0] VIDEO_PLAY ok
< 678.386> [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
< 678.390> [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
< 678.393> [eDVBVideo0] VIDEO_CONTINUE ok
< 678.396> [eDVBAudio0] AUDIO_CONTINUE ok
< 678.403> [eDVBTeletextParser] Starting!
< 678.403> [eDVBTeletextParser] disable teletext subtitles page ffffffffffffffff (und)
< 678.403> [eDVBPESReader] Created. Opening demux
< 678.403> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 678.403> [eDVBTeletextParser] created teletext subtitle PES reader!
< 678.403> [eDVBTeletextParser] starting PES reader on pid=ffffffff
< 678.406> [eDVBServicePlay] timeshift
< 678.409> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 678.410> [eDVBServicePlay] timeshift
< 678.412> [eDVBServicePlay] timeshift
< 678.413> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 678.414> [eDVBServicePlay] timeshift
< 678.462> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 678.463> [eDVBSectionReader] DMX_SET_FILTER pid=4096
< 678.465> [eDVBVideo0] VIDEO_GET_EVENT SIZE_CHANGED 704x576 aspect 3
< 678.482> [eDVBVideo0] VIDEO_GET_EVENT FRAME_RATE_CHANGED 25000 fps
< 678.483> [eDVBVideo0] VIDEO_GET_EVENT PROGRESSIVE_CHANGED 0
< 678.884> [eDVBServicePlay] timeshift
< 678.989> [VideoMode] setMode - port: HDMI, mode: 1080p50
< 679.269> [VideoHardware] setting aspect: 16:9
< 679.269> [VideoHardware] setting wss: auto
< 679.270> [VideoHardware] setting policy: bestfit
< 679.271> [VideoHardware] setting policy2: scale
< 680.067> [eEPGCache] start caching events(1523075748)
< 680.067> [eDVBSectionReader] DMX_SET_FILTER pid=3842
< 680.067> [eDVBSectionReader] DMX_SET_FILTER pid=3003
< 680.067> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 680.069> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 680.070> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 680.072> [eDVBSectionReader] DMX_SET_FILTER pid=700
< 680.073> [eDVBSectionReader] DMX_SET_FILTER pid=5000
< 680.074> [eDVBSectionReader] DMX_SET_FILTER pid=5000
< 680.075> [eDVBSectionReader] DMX_SET_FILTER pid=57
< 681.190> [eInputDeviceInit] 1 6a 1
< 681.193> [InfoBarGenerics] KEY: 106 RIGHT
< 681.529> [eInputDeviceInit] 0 6a 1
< 681.532> [InfoBarGenerics] KEY: 106 RIGHT
< 681.555> [ActionMap] InfobarChannelSelection RightPressed
< 681.559> [eFilePushThread] stopping thread
< 681.559> [eFilePushThread] STOP
< 681.565> [eDVBLocalTimerHandler] remove channel 0x1b395a0
< 681.566> [eEPGCache] remove channel 0x1b395a0
< 681.566> [eEPGCache] abort caching events !!
< 681.585> [eDVBServicePlay] timeshift
< 681.586> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 681.587> [eDVBServicePlay] timeshift
< 681.589> [eDVBServicePlay] timeshift
< 681.589> [eTSMPEGDecoder] decoder state: play, vpid=ffffffff, apid=ffffffff
< 681.589> [eDVBVideo0] DEMUX_STOP ok
< 681.590> [eDVBVideo0] VIDEO_STOP ok
< 681.593> [eDVBVideo0] destroy
< 681.593> [eDVBAudio0] AUDIO_STOP ok
< 681.618> [eDVBAudio0] DEMUX_STOP ok
< 681.618> [eDVBAudio0] AUDIO_CONTINUE ok
< 681.624> [eDVBAudio0] destroy
< 681.650> [eDVBServicePlay] timeshift
< 681.651> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 681.652> [eDVBServicePlay] timeshift
< 681.654> [eDVBServicePlay] timeshift
< 681.655> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 681.655> [eDVBServicePlay] timeshift
< 681.657> [eDVBServicePlay] timeshift
< 681.658> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 681.658> [eDVBServicePlay] timeshift
< 681.661> [Notifications] RemovePopup, id = ZapError
< 681.661> [eHttpStream] Start thread
< 681.662> [eDVBServicePMTHandler] no .meta file found, trying to find PMT pid
< 681.662> [eDVBTSTools] findPMT file not valid
< 681.662> [eDVBServicePMTHandler] alloc PVR
< 681.662> [eDVBChannel] getDemux cap=00
< 681.662> [eDVBResourceManager] allocate demux cap=00
< 681.662> [eDVBResourceManager] allocating demux adapter=0, demux=8, source=-1 fesource=-1
< 681.662> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 681.662> [eDVBTSTools] setSource loading streaminfo for xxx
< 681.662> [eDVBDemux] open dvr /dev/dvb/adapter0/dvr8
< 681.662> [eDVBServicePlay] cutfile not found!
< 681.662> [eDVBServicePlay] no cue sheet
< 681.670> [setIoPrio] best-effort level 0 ok
< 681.670> [eFilePushThread] START thread
< 681.670> [eDVBLocalTimerHandler] channel 0x1b395a0 running
< 681.670> [eDVBChannel] no cue sheet. forcing normal play
< 681.670> [eDVBChannel] getDemux cap=00
< 681.670> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 681.670> [eDVBSectionReader] DMX_SET_FILTER pid=20
< 681.670> [eEPGCache] channel 0x1b395a0 running
< 681.671> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 681.671> [eDVBServicePMTHandler] ok ... now we start!!
< 681.671> [eEPGCache] next update in 2 sec
< 681.671> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 681.672> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 681.677> [Notifications] RemovePopup, id = ZapError
< 681.790> [eHttpStream] openUrl: redirecting to:xxx
< 681.920> [eFilePushThread] wait for driver eof timeout
< 681.960> [eHttpStream] Thread end connection
< 682.170> [eFilePushThread] wait for driver eof timeout
< 682.172> [eDVBServicePMTHandler] PATready
< 682.172> [eDVBServicePMTHandler] use single pat entry!
< 682.172> [eDVBServicePMTHandler] use pmtpid 1000 for service_id 0001
< 682.172> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 682.172> [eDVBSectionReader] DMX_SET_FILTER pid=4096
< 682.173> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 682.173> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 682.174> [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
< 682.175> [eDVBServicePlay] have 1 video stream(s) (0100), and 1 audio stream(s) (0101), and the pcr pid is 0100, and the text pid is ffffffff
< 682.180> [eTSMPEGDecoder] decoder state: play, vpid=0100, apid=0101
< 682.184> [eDVBAudio0] DMX_SET_PES_FILTER pid=0x0101 ok
< 682.184> [eDVBAudio0] DEMUX_START ok
< 682.184> [eDVBAudio0] AUDIO_SET_BYPASS bypass=1 ok
< 682.190> [eDVBAudio0] AUDIO_PAUSE ok
< 682.192> [eDVBAudio0] AUDIO_PLAY ok
< 682.197> [eDVBVideo] Video Device: /dev/dvb/adapter0/video0
< 682.197> [eDVBVideo] demux device: /dev/dvb/adapter0/demux8
< 682.200> [eDVBVideo0] VIDEO_SET_STREAMTYPE 1 - ok
< 682.204> [eDVBVideo0] DMX_SET_PES_FILTER pid=0x0100 ok
< 682.204> [eDVBVideo0] DEMUX_START ok
< 682.204> [eDVBVideo0] VIDEO_FREEZE ok
< 682.207> [eDVBVideo0] VIDEO_PLAY ok
< 682.215> [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
< 682.218> [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
< 682.221> [eDVBVideo0] VIDEO_CONTINUE ok
< 682.224> [eDVBAudio0] AUDIO_CONTINUE ok
< 682.230> [eDVBTeletextParser] Starting!
< 682.230> [eDVBTeletextParser] disable teletext subtitles page ffffffffffffffff (und)
< 682.230> [eDVBPESReader] Created. Opening demux
< 682.230> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 682.230> [eDVBTeletextParser] created teletext subtitle PES reader!
< 682.230> [eDVBTeletextParser] starting PES reader on pid=ffffffff
< 682.231> [eDVBServicePlay] timeshift
< 682.232> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 682.233> [eDVBServicePlay] timeshift
< 682.235> [eDVBServicePlay] timeshift
< 682.237> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 682.238> [eDVBServicePlay] timeshift
< 682.266> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 682.266> [eDVBSectionReader] DMX_SET_FILTER pid=4096
< 682.661> [eDVBServicePlay] timeshift
< 682.662> [eDVBServicePlay] timeshift
< 683.680> [eEPGCache] start caching events(1523075752)
< 683.680> [eDVBSectionReader] DMX_SET_FILTER pid=3842
< 683.681> [eDVBSectionReader] DMX_SET_FILTER pid=3003
< 683.681> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 683.682> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 683.684> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 683.685> [eDVBSectionReader] DMX_SET_FILTER pid=700
< 683.686> [eDVBSectionReader] DMX_SET_FILTER pid=700
< 683.687> [eDVBSectionReader] DMX_SET_FILTER pid=5000
< 683.688> [eDVBSectionReader] DMX_SET_FILTER pid=57
< 685.293> [eInputDeviceInit] 1 6a 1
< 685.297> [InfoBarGenerics] KEY: 106 RIGHT
< 685.525> [eInputDeviceInit] 0 6a 1
< 685.528> [InfoBarGenerics] KEY: 106 RIGHT
< 685.551> [ActionMap] InfobarChannelSelection RightPressed
< 685.555> [Navigation] playing 1:0:1:0:0:0:0:0:0:0:http%3a//xxx
< 685.555> [eFilePushThread] stopping thread
< 685.555> [eFilePushThread] STOP
< 685.560> [eDVBLocalTimerHandler] remove channel 0x1b395a0
< 685.560> [eEPGCache] remove channel 0x1b395a0
< 685.561> [eEPGCache] abort caching events !!
< 685.580> [eDVBServicePlay] timeshift
< 685.581> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 685.582> [eDVBServicePlay] timeshift
< 685.584> [eDVBServicePlay] timeshift
< 685.584> [eTSMPEGDecoder] decoder state: play, vpid=ffffffff, apid=ffffffff
< 685.584> [eDVBVideo0] DEMUX_STOP ok
< 685.589> [eDVBVideo0] VIDEO_STOP ok
< 685.592> [eDVBVideo0] destroy
< 685.592> [eDVBAudio0] AUDIO_STOP ok
< 685.617> [eDVBAudio0] DEMUX_STOP ok
< 685.617> [eDVBAudio0] AUDIO_CONTINUE ok
< 685.623> [eDVBAudio0] destroy
< 685.648> [eDVBServicePlay] timeshift
< 685.649> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 685.649> [eDVBServicePlay] timeshift
< 685.651> [eDVBServicePlay] timeshift
< 685.652> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 685.652> [eDVBServicePlay] timeshift
< 685.654> [eDVBServicePlay] timeshift
< 685.655> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 685.656> [eDVBServicePlay] timeshift
< 685.658> [Notifications] RemovePopup, id = ZapError
< 685.659> [eHttpStream] Start thread
< 685.659> [eDVBServicePMTHandler] no .meta file found, trying to find PMT pid
< 685.659> [eDVBTSTools] findPMT file not valid
< 685.659> [eDVBServicePMTHandler] alloc PVR
< 685.659> [eDVBChannel] getDemux cap=00
< 685.659> [eDVBResourceManager] allocate demux cap=00
< 685.659> [eDVBResourceManager] allocating demux adapter=0, demux=8, source=-1 fesource=-1
< 685.659> [eDVBDemux] open demux /dev/dvb/adapter0/demux8
< 685.659> [eDVBTSTools] setSource loading streaminfo for xxx
< 685.659> [eDVBDemux] open dvr /dev/dvb/adapter0/dvr8
< 685.659> [eDVBServicePlay] cutfile not found!
< 685.659> [eDVBServicePlay] no cue sheet
< 685.660> Traceback (most recent call last):
< 685.660> File "/usr/lib/enigma2/python/Navigation.py", line 89, in dispatchEvent
< 685.661> File "/usr/lib/enigma2/python/Components/PerServiceDisplay.py", line 17, in event
< 685.661> File "/usr/lib/enigma2/python/Components/Sources/CurrentService.py", line 26, in serviceEvent
< 685.661> File "/usr/lib/enigma2/python/Components/Element.py", line 86, in changed
< 685.661> File "/usr/lib/enigma2/python/Tools/CList.py", line 3, in __getattr__
< 685.662> File "/usr/lib/enigma2/python/Components/config.py", line 2033, in getResolvedKey
< 685.662> TypeError: changed() takes exactly 2 arguments (3 given)
< 685.662> [ePyObject] (CallObject(<bound method Navigation.dispatchEvent of <Navigation.Navigation instance at 0x60cc0300>>,(10,)) failed)
dmesg
<4>[AUD]: AUDIO_CONTINUE -8 0 aph=0x0
<4>[AUD]: AUDIO_CONTINUE aph=0 0 0
<4>[AUD]: AUDIO_SELECT_SOURCE 0
<4>[AUD]: AUDIO_SET_BYPASS_MODE 1
<4>[AUD]: downmix 0 state : 0
<4>[AUD]: AUDIO_PAUSE -8
<4>[AUD]: AUDIO_PLAY -8 decoder start : 0
<4>[VID]: VIDEO_SELECT_SOURCE 0 0
<4>[VID]: VIDEO_SET_STREAMTYPE 1
<4>[VID]: VIDEO_FREEZE -8 0
<4>[VID]: VIDEO_PLAY -8 5 2
<4>[VID]: VIDEO_SLOWMOTION 0 1
<4>[VID]: VIDEO_FAST_FORWARD 0 1
<4>[VID]: VIDEO_CONTINUE -8 1
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xca021380
<4>[AUD]: Mute : 0
<4>[VID]: VIDEO_GET_SIZE src w: 0 h:0 display w:0 h:0
<4>[VID]: VIDEO_GET_SIZE aspect: 1 0
<4>[VID]: VIDEO_STOP 1 1
<4>[AUD]: AUDIO_STOP -8
<4>[AUD]: AUDIO_SET_MIXER -845627920
<4>[AUD]: AUDIO_SET_MIXER : amixl 45, amixr 45
<4>[AUD]: AUDIO_SET_MIXER : next left volume -2998, right volume -2998
<4>[AUD]: AUDIO_SET_MIXER : next left volume -3284, right volume -3284
<4>[AUD]: AUDIO_SET_MIXER : amixl 48, amixr 48
<4>[AUD]: AUDIO_SET_MIXER : next left volume -3498, right volume -3498
<4>[AUD]: AUDIO_SET_MIXER : amixl 51, amixr 51
<4>[AUD]: AUDIO_SET_MIXER : next left volume -3712, right volume -3712
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xcdb14200
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_SET_BYPASS_MODE 8
<4>[AUD]: AAC downmix 0 state : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xce3ce600
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xcf4f6d00
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xcf4f6a80
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xca024300
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xcfebb300
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xca01eb80
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xcff5b400
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xca18ba80
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xcf7cf380
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xcff5c580
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xcda7fc80
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CONTINUE -8 1 aph=0xce3d1d00
<4>[AUD]: Mute : 0
Creator = OpenBH
Version = 4.1
Build = 024
Type = release
Machine = vuduo2
Component = Enigma2
Type: DVB-S2
Frontend_Device: 0
I2C_Device: 2
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
I2C_Device: 3
/demux8
dmesg
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
