IPTV - EPG
jobu71
Situation= VU+Duo Blackhole Have All local DVB channels working & showing EPG ok
Have loaded IPTV channel list & all working fine... BUT NOT showing EPG
EPG not working... Strange - help needed I have EPG.xml file
Which folder ( FTP ) should the EPG.xml file be in the Blackhole EPG system?
I used E-channelizer ( very good ) program to create & assign EPG IDs I also loaded EPG URL & used "EPG Importer" on duo. When I run EPG importer ( after marking off the E-Channelizer EPG ) in EPG importer, it loads a whole load of info,
but does not show up on the IPTV channels Bouqet
Can anyone help with this?
Kind regards
Jobu71
Kind regards
Jobu71
To my Knowledge, EPG comes from the TV/IPTV providers.
I have the same issue , but could not find a solution.
The best way to use iptv ang get epg is to use jediimakerxtreme plugin.Then you can choose what bouquets you want as well as get the epg
