iptv help
hashman
Hi
I have setup some free religious IPTV channels for my parents on a VU+ solo2
These work perfectly on my box with openBH 1.0.... but doesnt at my parents house.
I have reinstalled image and everything.....
I get an error message saying :
"No data on transponder (timeout reading PAT)"
The internet works fine on the box as I can connect remotely... and speed is fine too, I ran a wget on a 1GB test file on thinkbroadband and it took about 10min to fully download, so box connection can't be it.
Did I install a library which I can't remember that I need to install on my parents box?
Did you test those channels in your box ?
I clearly suspect that IPTV links are not good made.
The message you get shows that the receiver sees links as a satellite channel rather than as an IPTV.
I am not sure what it was, but I gaveup and reflashed open bh again as crossepg was not working....
did nto fix crossepg (rytec update problems) but fixed the iptv :)
I have copied over my crossepg files from my box to my parents - so that is sorted too now
thanks
