IPTV on solo2 problem
hazzhass
What is the cause of this error when playing iptv channels? These teledunet channels works in other images, open spa, vti, openvix , no problems, so not website problem....
Solved, some BH files are out of date ... needs updating,, so I did it from OE alliance image!!!
Very disappointed with this beautiful image, not receiving tender loving care TLC from people behind it.
Hi hazzhass,
Can you explain how did you update the BlackHole image files from 0E alliance image, because I would like to use this teledunet channels plugin? Thanks.
you need to delete librtmp.so.0 , and add instead librtmp.so.1 (from openatv 4.2 or any other oe alliance decent image) , then rename the file to librtmp.so.0
reboot
reboot
Hi
is it possible te take the file (librtmp.so.1)from my Vu+ Duo with openATV image and put it to my Vu+Solo2 with BlackHole image 2.1.0.1? Is there a risk ? Thanks
yes possible, but you have to rename it to librtmp.so.0
i think BH team should solve this issue , rather me updating their image!!!
