IPTV on VUDUO
daif01
I have VU+DUO. Black Hole 1.7.8. I recentlly moved to new flat, where in not allowed to have sat dish. The only think that can save me is streaming iptv channels on my vuduo. i was able to stream some few channels via the plugin (ADD stream URL). The problem is it streams only some (rtmp) links. I used to first test the link with vlc and SMplayer, most of channel links works with vlc and SMplayer, but only very few rtmp links works with vuduo.No http or rtsp links works with vuduo.I tried to edit xml file of Stream tv player plugin, but not working. my box is connected to internet via LAN, and when i test my intrenet speed it is download speed 70mb/sec and upload 60mb/sec.
Any one who managed stream mms or http via add stream URL?
Any suggessions is appeciated.
thanks in advance.
best regards.
This is all done directly from the satellite bouquet list
You do not need a plugin.
http and rtsp
Example:
#NAME Favourites (TV)
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//hdimages.cdnvideo.ru/rr/HDextremeCDN
#DESCRIPTION HDextreme
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//93.95.98.28%3a8100
#DESCRIPTION HD MEDIA (RUS)
IPTV
sort of quick how-to IPTV, in general:
for .ts streams
#SERVICE 1:0:0:0:0:0:0:0:0:0:link_to_your_stream#DESCRIPTION any_stream_name_you_want
and for all non-ts streams:
#SERVICE 4097:0:0:0:0:0:0:0:0:0:link_to_your_stream#DESCRIPTION any_name_you_want
and two hints:
1. in the link_to_your_stream you have to replace all the colons : with %3a
eg (fake link):
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtmp%3a//blah.blah.zy%3a1234/%3amusic.stream
2. entries can be added to any bouquet in /etc/enigma2:stop enigma2 (init 4) > add your entry(ies) > start enigma2 (init 3)​
example you can test I think is working:
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//hdimages.cdnvideo.ru/rr/HDprocessCDN
#DESCRIPTION HDprocess
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//hdimages.cdnvideo.ru/rr/HDtravelCDN
#DESCRIPTION HDtravel
#DESCRIPTION HD MEDIA (RUS)​
Thank you vaery much for your help and quick answer.Yes , im adding the streams directly to bouquet via DCC. despite of that most streams that work with vlc , deos not work with vuduo. would it be better if i download gst-plugin-rtpmux and rtpvp8 from package list. Why threre is no gst-plugin -mms in package list? how i know the link is ts or non ts ? what do mean by ts?
thanks in advance
http and rtsp
Example:
Unfortunately I'm not using IPTV
So I can not give an answer.
I just wanted to show you that it works.
Now the second question is with what strems it works
and whether you need to install additional packages.
Maybe someone can help you more.
Matrix10 - where does one enter the text you have provided? (with altered rtsp address of course) - do you ftp it to a folder in your box? I have a vu duo running blackhole. Please advise
