iptv y blackhole
verbatov
hola buenas tardes,
a lo mejor alguien me puede echar una ayuda...
se congela la imagen de los canales iptv en mi vu+ solo se con blackhole a los pocos segundos de reproducirlos, esto me pasa en todos los canales...el caso es que con el vlc en el pc me ván bien
a alguien le ha pasado lo mismo y lo ha solucionado ?
gracias y un saludo
hola buenas tardes,
gracias y un saludo
A mí me pasaba igual con un vu+ zero 4k y con Openspa me va bien.
Enviado desde mi ONEPLUS A6003 mediante Tapatalk
How do you setup your IPTV?
Do you use any plugin to create bouquets or do you play straight from an .m3u file?
So you play your M3u file direct throug the mediaplayer?
I would recommend you use a plugin to convert the m3u to bouquets and view them from the channel list instead.
Try Autoboquet maker its in the Blackhole plugin feeds or use JediMakerXtream to convert m3u to playable channels.
JediMakerXtream is not in the Blackhole plugin feeds but if you google it you find the plugin on the internet.
My experince is that Blackhole 3.0.8.C works just as good as OBH now with IPTV
ServiceApp is very good addon if you have a bad m3u but 95% of all plays just fine with standard DVB1
If you have JediMakerXtream installed just upload with ftp to folder /etc/enigma2/jediplaylists and create your bouquets to view your m3u file
