IPTVListUpdate help
olindo
I have my VU+ DUO original.
I installed the latest version 2.0.7.3 (OE 2.0)
Have installed many plugin,but can't not install IPTV ListUpdate 1.30
How to do to install this plugin..?
I had the same promblemu on this image but only as set
first from the post after 67 utanovi tmp file 2
1.librtmp1 2.4
2.udpxy 0.23
http://www.vuplus-community.net/board/threads/iptv-channel-updater.12992/page-4
then loads
of post 53
http://www.vuplus-community.net/board/threads/iptv-channel-updater.12992/page-3
iptvlistupdater_1.10. + git288 +929970 d-r8
After installing the plugin overload fully displayed in the Plugins panel
Then put the handles of the new folder latest version IPTVlistUpdater1.30 with replacement Again overload of Next plug renew favorite lists those programs which have
I just so happened I wish you luck
I tried to install these plugin from "manual install ipk" in VU+ Duo, but nothing
After, from Telnet I write these:
- opkg update
- opkg install -force-overwrite /var/volatile/librtmp1_2.4+git490+a9f353c-r3_mips32el.ipk
but not installed ...look this :
Installing librtmp1 (2.4+git+490+a9f353c-r3) to root...
Configuring librtmp1.
Collected errors:
* opkg_run_script: package "librtmp1" postinst script returned status 1.
* opkg_configure: librtmp1.postinst 1.
Extecution finished !!
How to install with this error now..?!!!
I installed through the / tmp
Try to install the skin by default
I use skin Matrix 2.14
And to do so we must
We first establish the file do ( udpxy 0.23 ) on full overload
then installed through / tmp file.( librtmp1 2.4 )as well do a complete restart
on set( iptvlistupdater_1.10. + Git288 +929970 d-r8 ) and a complete restart as well
I did so and I was able to try a week though differently
and did not work
Samples should turn
Good luck
Hi to all,
i have installed with success, but at the end I get the following message for every new installation.
Collected errors:
* pkg_run_script: package "librtmp1" postinst script returned status 1.
is there any way how to fix it?
Thanks
Hi to all,
Collected errors:
Thanks
install first
1.librtmp1 2.4
2.udpxy 0.23
and then iptv 1.30
it should be ok
it should work fine with this image.are you restarting box after every file installation?
Hi Yannis_d,
I have BH 2-0.8 installled on my Vu+duo. I installed updater list, but also I have the same problem as olindo and konstantinud. Can you fix it?
i installed 208 right now,ican see it in the plugin menu.it works.try with this files:
Hi,
I have installed it , no problem, it works. But I ask you about this message:
Collected errors:
It's appeared after each instalation, even other plugins.
Thanks
