is blindscan in 2.07-1 any better
iwols
hi all at work at the minute so cant try it ,but ive noticed the blindscan has been updated in this fw ,does anyone know if it is better than before thanks
I do not see much difference on a couple of test scans here in the United States. The BlackHole Blindscan does not work for me on C band, and Ku scanning is extremely slow. Some other VU+ Duo2 firmwares have a decent or acceptable blindscan, and I hope the BlackHole blindscan will be drastically improved in the future.
hello please why there is not blindscan in all your images vu+duo ???
in dreambox boxes there is but not vu+
i think it is not difficult to add this plugin
please can you add it because it is very important plugiin for seraching channels
i wait an answer friom you
The answer is simple: not all Vu+ boxes supports Blindscan and the corresponding plugin is avaiable ONLY on Vu+ boxes that support it
