ISP and home network speed check
meloserj
Hello mates
Was looking for a plugin or netperf script for Vu+ uno 4k SE with lates OBH 4.4, but couldn't find so far.
Your kind help is appreciated for guiding me.
P.S: Don't want to use KODI which I read inside it has speedtest from Ookla.
Cheers
Why on earth do you want to use a VU+ to measure the speed of the Internet connection? Can't you do by a normal PC or even a smartphone?
Charging of useless plugins a VU+ (which is not exactly a computer, although it runs an operative system similar to Linux) is not a great idea.
Hello mates
Cheers
Google for it:
netspeedtest enigma2
Yes bro I know its not a computer, but there would be situations which you need to check the speed directly from the box. When Xbox has it, Smart TVs have it, so why OBH won't?
It's called Net Speed Test. A test on Zero 4K with OBH:
