Hello
I tried to update drivers from VUCC with last drivers that offer this software (December 2016) and my vuplus dont work, it start but buttons dont work.
I put your last BlackHole-3.0.3-vusolo2_usb_release_20170327 in pendrive of 16GB formated in FAT32 and pluged it before start with reset button but solo2 dont read never the pendrive, I cant see "Press Power for install". I only see in screen "Starting" and 1 min after "VU SOLO2"
Years ago I remember this problem and I believe remember that I solved this issue holding power button during for 10 seconds or so (maybe it worked pressing button 5 times, I dont remember...)
Do you can suggest me any solution to can install new black hole or make backup my old blackhole 2.1.1 ?
Best regards
Best regards
