Issue with audio SD CHANNEL in vu+solose
hichamVUDUO
HELLO
i have audio problem with all SD CHANNEL, when i select HD CCHANNEL i can here song but not when i shoose SD CHANNEL. The last time in BH 2.1.7 I had to reflash . now with 3.0.1 I started having this problem since yesterday.
thank you for giving me a hand.
Have you checked your audio options, on the SD channels?
Does this happen on every SD channel or just a particular channel?
Is your receiver connected to your television by a HDMI cable, scart cable, or are you using a separate audio system?
The more technical ionformation, you provide, the better.
I can't think of any reason that a HD channel works, whereas a SD channel doesn't, unless it's to do with the selected Audio options.
thanks for helping.
my receiver is connected by HDMI direct to SONY BRAVIA tv.
i have checked the audio option on/off dolby... no results
great thanks
Can you please describe your satellite setup, Single fixed dish, Motorized dish, multiple LNB's, and Diseqc switch, etc., and which satellites you can receive, and the channels you're having problems with.
I would check lyngsat, and kingofsat, for the channel details, then do a manual scan, ensuring you have the clear before scan option selected.
