Issues: Deep Standby with BlackHole 3.0.3 and Elektro Power Save Plugin
Master Proper
Hello,
thanks for the great work on the BlackHole image. After staying with 2.x versions for some time, I have just upgraded to BlackHole 3.0.3 and noticed some issues.
- BlackHole 3.0.3 does not offer deep standby in the selection of shutdown options (using BlackHole 3.0.3 from usb with openmultiboot - BlackHole 3.0.3 is also in the flash)
- After installing the Elektro Power Save Plugin the box asks to restart the gui and hangs when doing so (using BlackHole 3.0.3 from usb with openmultiboot - BlackHole 3.0.3 is also in the flash). Only an opkg remove and restart of gui with init 4 && init 3 helps
How can I solve these issues or is it a "feature" not to offer deep standby?
Thanks for your support.
Regards,
Master Proper
