Issues with playback of mkv (1080p) and divx?
Bjorhal
Hello!
I am currently using the VTI 2.5 image which has several issues with 1080p MKV-files (freeze, 1080i works fine) and DIVX-files (juddering). While searching for a solution i found this forum. Does the Blackhole image have the same difficulties playing those formats?
Thank you for your advise.
Bjorhal
Hello!
Bjorhal
I've played correctly a 1080P mkv file located on the internal HDD of Duo box.
For Solo box I've not tested the same file.
I will make some tests with the samek MKV file on the Solo this weekend.
That would be nice. Just for info: I use the Autoresolution plug in. The box plays the 1080p files when the are scaled down to 1080i for example. When I want the box to playback 1080p as 1080p it freezes.
