It work OpenMultiboot for internal HDD?
BLIND-EYE
Vu+Uno with B H 2.1.7 in the flash.
Internal HDD mounted as /media/hdd
Only with to active OpenMultiboot (without intsall none image) the B H 2.1.7 become corrupted.
With B H 2.1.4 and Meoboot work fine but there is not inside drivers for my Vuplus Turbo DVB-T Tuner.
It´s not only install Open Multiboot on HDD ... You must have a EXT4 partition to use OMB.
It´s not recommend use a HDD for Open Multiboot, it´s recommended use an USB Pen Drive fromatted to EXT4 FileSystem. See the Guide on How to Use Open Multiboot!
Best regards
Not work, it stop during the installation of OpenBH in the pendrive with ''ERROR, MTD NOT FOUND'', then it corrupt the BH 2.1.7 in flash I must flash the BH 2.1.7 again.
USB Pendrive partition sdb1 formated EXT4 mounted /media/usb
I sur.render.
