Jedi EPG Xtream
josagi
Vu+ User+++
Jedi EPG Xtream
Assign 3rd Party EPG to IPTV Channels
Plugin will work on 720 or HD boxes.
There is nothing over complicated in this plugin and should therefore work on all images.
It has only been tested on OpenATV for this release.
How to use
Plugin is found in plugins menu.
Plugin loads all bouquets from bouquets folders except bouquets created via Auto Bouquets Maker.
Therefore can be used with any bouquet creating plugin not just my Jedi Maker Xtream.
Column 1 - Bouquets
This will load all your bouquets as found in
/etc/enigma2/
If bouquets are grouped it will load parent group. Pressing right or OK will load sub-bouquets.
Column2 - Channels
This loads all the channels from the selected bouquet.
If a channel has an EPG already assigned via this Jedi EPG Xtream plugin a LINK icon will show next to it.
Can unassign an EPG from the channel by pressing GREEN Button while that channel is highlighted.
Column3 - EPG sources
This loads a list of EPG sources that are defined in an editable file - epglist.txt
/etc/enigma2/jediepgxtream/epglist.txt
I have added in all the Rytec sources into this file, and 2 other working sources.
If using Jedi Maker Xtream playlists, these xmltv.php sources will also automatically be added to the EPG source list on load.
You can also use any active xmltv.php file to populate other providers.
Other 3rd party EPGs can be added. But EPG importer cannot use https:// sources though
Sources can be xml, xz, gz or an active iptv xmltv.php links
To edit the epglist.txt file, 2 elements are required. A name and a source separated by a single space.
The name has to be file name friendly. So use only Alpha-numeric characters and hyphens. Do not use \/.?* or spaces.
good example:
Rytec-News-Channels [url]http://www.xmltvepg.nl/rytecNWS.xz[/url]
bad examples:
Rytec News-Channels [url]http://www.xmltvepg.nl/rytecNWS.xz[/url]
Rytec/News/Channels [url]http://www.xmltvepg.nl/rytecNWS.xz[/url]
I have pre-downloaded all the sources data in compact form.
Sources can be refreshed by pressing YELLOW button or OK button if source list is empty (optional), or can be hidden by pressing BLUE button.
Hiding the source just comments it out of epglist.txt file. It does not permantly delete it.
Column 4
This column only lists active channels that has EPG data. It does not list channels that are named but has blank EPG data.
Therefore this plugin can actually be used to check your providers XMLTV file to see what actual channels should have EPG.
Press OK or GREEN button will assign this EPG to the channel.
On assigning it will jump back to column 2 to allow further adding of channel EPGs.
On assigning - everything is automatically created in the background. No further saving need, just exit out of the plugin to finish.
Navigation Buttons
Left
Right
Up
Down
Channel up - Page up
Channel Down - Page down
0 - Back to top
2 - Previous Letter
8 - Next Letter
EPG Importer
Open EPG importer.
Press BLUE button for "Sources".
Expand "Jedi EPG"
Select all sources.
Save
Press YELLOW button to manually download sources.
How to delete all assigned EPGs and start from scratch.
delete epg.json from /etc/enigma2/jediepgxtream/
Thanks KiddaC
  • enigma2-plugin-extensions-jediepgxtream_1.04.20200116_all.ipk
kadehte
hello, I tried this plugin with Vu Zero 4k OBH image. unfortunately not done. Have you tried it and with which image?
Thank you
josagi
Vu+ User+++
Jedi EPG Xtream Version 1.06
-New version trying a slightly different approach.
-Fixed a few more little bugs too.
-And added in an option to unassign all from that bouquet.
  • jediepgextream.zip
  • enigma2-plugin-extensions-jediepgxtream_1.06.20200117_all.ipk
josagi
Vu+ User+++
Jedi EPG Xtream v1.08
@KiddaC
Hopefully fixed non english characters in bouquet file names. Especially Greek letters.
  • enigma2-plugin-extensions-jediepgxtream_1.08.20200118_all.ipk
josagi
Vu+ User+++
Jedi EPG Xtream Version 1.09
-A few more little tweaks to get foreign characters to work.
-Fixed incorrect variable name preventing the plugin loading.
-Fixed bouquet list - now only shows live and not vod and series (if created via Jedi Maker Xtream)
-Added in more remote control key mapping for navigating around my plugin.
-Fixed some images not liking a jedimakerxtream reference I am looking up in the settings file.
-Fixed - bouquets that did exist, but were then deleted afterwards was causing a crash.
-Added in an option to unassign all from that bouquet.
-Fixed last channel in bouquet getting ignored.
-Added in dreamOS skin, so that should no longer crash
  • enigma2-plugin-extensions-jediepgxtream_1.09.20200118_all.ipk
josagi
Vu+ User+++
Jedi EPG Xtream v1.10
Fixed an error in the 720 skin that was crashing dreambox images. (I think)
Made column heading translatable.
Added in a few more epg sources that people have suggested
  • enigma2-plugin-extensions-jediepgxtream_1.10.20200120_all.ipk
josagi
Vu+ User+++
Jedi EPG Xtream V.1.11
-Fixed the multi colour backgrounds on dreambox
-Bouquets column is no longer sorted a-z
-Assigned sources and selections now get highlighted in the appropriate column
-Removed epg.json from the ipk, so your own will not get overwritten on plugin updates
-Added a few more loop breaks to try to stop some duplicate assigments
  • enigma2-plugin-extensions-jediepgxtream_1.11.20200121_all.ipk
AlexWilMac
Moderator
Well... as a BH lover it sounds a bit inappropriate you use PLI! At least you could be a OBH user if you prefer the open images... ;)
Fredriko
I tried this on my Vu+ Duo² with BlackHole 3.0.9.C When I try sto start the plugin after installation, the box crashes... Any tips?
maaric
I tired with jediMaker , but when i assign a other source nothing has changed in my EPG .Thought this plugin would end my EPG nightmare but i guess i need to search further
PhantomXP
Crash
Pure2 Enigma2 crash log
crashdate=Di Mai 26 04:29:09 2020
compiledate=May 18 2020
skin=Estuary/skin.xml
sourcedate=2020-05-17
branch=6.5
rev=gst16.x-configs-397-g217785c
component=Enigma2
stbmodel=solo2
stbmodel=dm8000
kernelcmdline=ubiroot rootflags=sync bmem=192M@64M bmem=256M@512M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs
nimsockets=NIM Socket 0:
imageversion=box_type=vusolo2
imageissue=
 a tuple.
04:28:08.6933 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:08.6958 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:08+0200 [-] KEY: 108 1
04:28:08.7835 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:08.7856 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:08+0200 [-] KEY: 108 0
04:28:08.7877 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:08+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:08.7911 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:08.7913 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.0152 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:09.0183 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 1
04:28:09.0435 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:09.0458 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 0
04:28:09.0479 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:09.0516 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.0517 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.2753 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:09.2774 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 1
04:28:09.3036 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:09.3060 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 0
04:28:09.3083 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:09.3136 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.3137 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.4282 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:09.4306 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 1
04:28:09.5183 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:09.5208 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 0
04:28:09.5229 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:09.5264 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.5265 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.6432 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:09.6453 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 1
04:28:09.7438 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:09.7458 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 0
04:28:09.7479 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:09.7513 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7515 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7516 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7517 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7518 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7519 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7520 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7521 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7522 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7523 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7524 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7525 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7526 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.7527 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:09.9752 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:09.9773 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:09+0200 [-] KEY: 108 1
04:28:10.0038 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:10.0060 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:10+0200 [-] KEY: 108 0
04:28:10.0082 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:10+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:10.0116 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:10.0117 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:10.2353 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:10.2374 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:10+0200 [-] KEY: 108 1
04:28:10.7237 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:10.7258 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:10+0200 [-] KEY: 108 0
04:28:10.7279 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:10+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:10.7313 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:10.7314 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:10.9716 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:10.9737 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:10+0200 [-] KEY: 108 1
04:28:11.0668 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:11.0691 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:11+0200 [-] KEY: 108 0
04:28:11.0711 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:11+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:11.0749 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:11.0751 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:11.2982 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:11.3004 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:11+0200 [-] KEY: 108 1
04:28:11.3406 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
04:28:11.3429 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:11+0200 [-] KEY: 108 0
04:28:11.3451 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:11+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'down'.
04:28:11.3488 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:11.3489 [   ] gui/elistboxcontent.cpp:881 paint eListboxPythonMultiContent did not receive a tuple.
04:28:11.5682 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
04:28:11.5703 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:11+0200 [-] KEY: 108 1
04:28:16.4963 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 191 1
04:28:16.4989 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:16+0200 [-] KEY: 401 0
04:28:16.9737 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 191 1
04:28:16.9758 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:16+0200 [-] KEY: 401 1
04:28:16.9784 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:16+0200 [-] [ActionMap] Keymap 'ColorActions' -> Action = 'blue'.
04:28:17.5141 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 191 1
04:28:17.5162 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:17+0200 [-] KEY: 401 0
04:28:17.9716 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 191 1
04:28:17.9737 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:17+0200 [-] KEY: 401 1
04:28:17.9764 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:28:17+0200 [-] [ActionMap] Keymap 'ColorActions' -> Action = 'blue'.
04:28:34.0020 [   ] service/servicedvb.cpp:1131 gotNewEvent [eDVBServicePlay] pts of eit change: 1d059cf6e, fixup_pts: 200d780, first_pts: 1ce58f7ee
04:29:04.3234 [   ] service/servicedvb.cpp:1131 gotNewEvent [eDVBServicePlay] pts of eit change: 1d0833386, fixup_pts: 22a3b98, first_pts: 1ce58f7ee
04:29:05.3235 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.3239 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.3249 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.3301 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.3305 [   ] dvb/demux.cpp:949 stopPID [adenin]rmove PID 99(0x0063)
04:29:05.3307 [   ] dvb/demux.cpp:949 stopPID [adenin]rmove PID 1023(0x03ff)
04:29:05.3308 [   ] dvb/demux.cpp:949 stopPID [adenin]rmove PID 1027(0x0403)
04:29:05.3327 [   ] dvb/filepush.cpp:631 stop [eFilePushThreadRecorder] stopping thread.
04:29:05.3332 [   ] dvb/demux.cpp:624 flush [eDVBRecordFileThread] waiting for aio to complete
04:29:05.3333 [   ] dvb/demux.cpp:630 flush [eDVBRecordFileThread] buffer usage histogram (40 buffers of 192 kB)
04:29:05.3333 [   ] dvb/demux.cpp:633 flush       0:      6
04:29:05.3334 [   ] dvb/demux.cpp:633 flush       1:   1378
04:29:05.3334 [   ] dvb/demux.cpp:633 flush       2:   1300
04:29:05.5843 [   ] dvb/filepush.cpp:615 thread [eFilePushThreadRecorder] THREAD STOP
04:29:05.5880 [   ] service/servicedvb.cpp:2610 stopTimeshift [eDVBServicePlay] remove timeshift files
04:29:05.5884 [   ] base/thread.cpp:66 runAsync [eThread] old thread joined 0
04:29:05.5886 [   ] base/ioprio.cpp:91 setIoPrio [setIoPrio] best-effort level 7 ok
04:29:05.5888 [   ] components/file_eraser.cpp:91 gotMessage [eBackgroundFileEraser] deleting '/media/hdd/timeshift/timeshift.3rGUx3.del'
04:29:05.5891 [   ] components/file_eraser.cpp:91 gotMessage [eBackgroundFileEraser] deleting '/media/hdd/timeshift/timeshift.3rGUx3.sc.del'
04:29:05.5894 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.5902 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.5907 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.5914 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.5918 [   ] service/servicedvb.cpp:2511 startTimeshift [eDVBServicePlay] Start timeshift!
04:29:05.5924 [   ] service/servicedvb.cpp:2542 startTimeshift [eDVBServicePlay] timeshift recording to /media/hdd/timeshift/timeshift.hCvwa6
04:29:05.6434 [   ] base/ioprio.cpp:91 setIoPrio [setIoPrio] realtime level 7 ok
04:29:05.6435 [   ] dvb/filepush.cpp:546 thread [eFilePushThreadRecorder] THREAD START
04:29:05.6436 [   ] dvb/demux.cpp:929 startPID [adenin]add PID 99(0x0063)
04:29:05.6440 [   ] dvb/demux.cpp:929 startPID [adenin]add PID 1023(0x03ff)
04:29:05.6444 [   ] dvb/demux.cpp:929 startPID [adenin]add PID 1027(0x0403)
04:29:05.7005 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:05+0200 [-] [TIMESHIFT] - in method 'eEPGCache_saveEventToFile', argument 3 of type 'eServiceReference const &'
04:29:05.7013 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.7020 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.7025 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:05.7033 [   ] service/servicedvb.cpp:1747 timeshift [eDVBServicePlay] timeshift
04:29:09.0736 [   ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
04:29:09.0758 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-] KEY: 352 0
04:29:09.0779 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-] [ActionMap] Keymap 'SetupActions' -> Action = 'ok'.
04:29:09.0865 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-] Traceback (most recent call last):
04:29:09.0886 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]   File "/usr/lib/enigma2/python/Components/ActionMap.py", line 58, in action
04:29:09.1017 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]   File "/usr/lib/enigma2/python/Plugins/Extensions/JediEPGXtream/main.py", line 779, in ok
04:29:09.1054 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]     self.keygreen()
04:29:09.1074 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]   File "/usr/lib/enigma2/python/Plugins/Extensions/JediEPGXtream/main.py", line 744, in keygreen
04:29:09.1109 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]     self.assignEPG()
04:29:09.1129 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]   File "/usr/lib/enigma2/python/Plugins/Extensions/JediEPGXtream/main.py", line 1209, in assignEPG
04:29:09.1166 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]     self.buildXMLSourceFile()
04:29:09.1183 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]   File "/usr/lib/enigma2/python/Plugins/Extensions/JediEPGXtream/main.py", line 1287, in buildXMLSourceFile
04:29:09.1218 {   } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-]     with open(sourcepath, 'w') as f:
04:29:09.1244 { E } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2020-05-26 04:29:09+0200 [-] IOError: [Errno 2] No such file or directory: '/etc/epgimport/jex.epg.sources.xml'
04:29:09.1248 [ E ] python/python.cpp:210 call [ePyObject] (PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x68b23b98>>,('SetupActions', 'ok')) failed)
dmesg
<4>[VID]: VIDEO_SET_STREAMTYPE 0
<4>[VID]: VIDEO_SELECT_SOURCE 1  1
<4>[VID]: VIDEO_PLAY 1  2 0
<4>[VID]: VIDEO_CONTINUE 1  1
<4>[VID]: VIDEO_CLEAR_BUFFER 1  1 0
<4>[VID]: VIDEO_STOP 0  1
<4>[VID]: VIDEO_SELECT_SOURCE 0  0
<3>[LCD]: unknown cmd 0x1015
<3>UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
<4>[AUD]: AUDIO_SET_MUTE 0
<4>[AUD]: AUDIO_SET_MIXER -866779656
<4>[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
<4>[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>FE tune
<4>[AUD]: AUDIO_SELECT_SOURCE 0
<4>[AUD]: AUDIO_SELECT_SOURCE clean up
<4>[AUD]: AUDIO_SET_BYPASS_MODE 0
<4>[AUD]: AC3 downmix 0  state : 0
<4>[AUD]: AUDIO_PAUSE 0
<4>[AUD]: AUDIO_PLAY 0 decoder start : 0
<4>[VID]: VIDEO_GET_SIZE src w: 1152 h:720 display w:1280 h:720
<4>[VID]: VIDEO_GET_SIZE aspect: 1 3
<4>[VID]: VIDEO_SET_STREAMTYPE 1
<4>[VID]: VIDEO_FREEZE 0  0
<4>[VID]: VIDEO_PLAY 0  5 2
<4>[VID]: VIDEO_SLOWMOTION 0    1
<4>[VID]: VIDEO_FAST_FORWARD 0    1
<4>[VID]: VIDEO_CONTINUE 0  1
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xc4ea2900
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CHANNEL_SELECT 0
AlexWilMac
Moderator
This is NOT the Pure2 forum: this is the BlackHole & OpenBlackHole forum. Send it to them.
I've been trying this image in multiboot, just for curiosity: my personal opinion that is a jungle of icons, something done to satisfy the fashion of having icons everywhere.
It reminds me of the stupidest windows ever made, win8, with its "blanket" of icons.
This is the world where the look is more important than the effectiveness and the functionality.
And, not enough for this image, it immediately started having crashes for no reasons but just when I restarted GUI!
But surely, their forum will be plenty of helpers. Good luck.
Moderator
@PhantomXP
There is missing file /etc/epgimport/jex.epg.sources.xml
Thanks.. No more crash..:)
We are all glad that you solved your issues, but:
1) Next time, don´t ask at BlackHole or Open Black Hole support section anything related to other images.
2) If the plugin used is related to the use of Black Hole or Open Black Hole images, ask on the forum related to this ones, and on the section related to your Stb model.
Please note, that we can´t, we won´t support other images rather BlackHole or Open Black Hole.
nunigaiia
