Jedi EPG Xtream
josagi
Vu+ User+++
Jedi EPG Xtream V.1.13
-Now python 3 compatible
enigma2-plugin-extensions-jediepgxtream_1.13.20201127_all.ipk
https://mega.nz/file/GIUkVD6C#7pf5IXVkQdRdG_ljpivfxYpvCQDq2Vrv8K_WUUGYWzk
New
Jedi EPG Xtream V.2.00
whats new....
KiddaC wrote
Well basically I gave it some love and refactored all the code and skins.
•New skin code, so should be 100% compatible with dreamboxes
•New previous (2) / next letter (8) code that works on all 4 columns
•New fuzzy logic for finding close matches for images that have fuzzywuzzy module in their feeds
•Fallbacks to old logic for images that dont have fuzzywuzzy (dreamboxes)
•EPG Selection column now only shows close matches for simplicity
•Faster downloading and parsing of the files. Huge files are much much quicker now.
•EPG sources is no longer sorted and follows the /etc/enigma2/jediepgxtream/epglist.txt file structure
I have commented out the GEN sources in this release. They are UK football blocked and are down more than they are up.
In the epglist.txt there is also now a new Rytec-ALL that can be used instead of all the individual Rytec sources. Note this ALL file is a bit laggy on load though, but more convenient.
•New helper text at top, so you know what is going on, rather than just watching a loading circle unaware if anything is happening.
•New Logo
•New plugin icon
Has been tested on python 2.7 / python 3 and dreamboxes
Thanks KiddaC
