Ka- Band on vu duo2
teto.71
Hi guys
seen that there are channels that broadcast in the infamous Ka-band (not just internet services) designed to extend the scan frequency band tuners on because apart from the replacement of the lnb and the displacement frequency is a normal signal dvb s / 2
Greetings to all and thanks
Hi guys
It's not clear what you mean.
I just wanted to know if it will be extended frequency spectrum of a tune admissible 18000 mhz for example
Xperia z1 Compact smartphone
I think it's possible to use KA LNB on Enigma2 boxes.
It's important to check Enigma2 LNB configuration if the software allows LNB settings to cover KA specs.
I felt I had Angelo(I wanted to test to inverto lnb to the Ka-band means). I did not find the settings to do so anyway (I had the BH 2.0.9.1). but nothing even writing the frequency in the manual search gave me nothing to do 0 channels found
