kodi 16.0 vusolo4k
mouni
openpsa vuplus-kodi-vusolo4k_16.
is possible to fix whith blackhole?
Openspa developers create version to his image.
Is no easy run this on BH image becouse BH based on orginal image.
Hi
I use the Black Hole 3.0.2.A Kodi Image and have some issues with kodi
copy that from the Shootbox:
  1. Gestern um 22:08 Uhr - Norskman:
    vu solo+ works - no problem. KOdi it only shows half the front screen so cannot add any new area - I can see just a bot of what shold be on the right side - just a small vertical white line. The redto f kodi works fine V3
i have the same Problem cause the Button,in German,"Anzeigemodus" or inEnglish "display mode" is not Active so i have only small Picture of Kodi on my Tv Screen therefore it´s not usebale for me at this Time
The Pictuers are show you what im trying to explain,1th is from my PC 2nd is from the
the Vu4K taken with a Handy cause grab -d shows only a black screen.
also i can´t not Install Files via a so called zip File Error massage says i have no Internet connection
Hope this can be Fixed
Hi
Thx for the Fix now the Kodi Window is in Full Screen and i can also
Install "zipFiles"
but anyway it would be nice if you notify us if you repaired somethings
if I had not accidentally taken a software update then I would not know it
