Ev0
Admin
With OBH 4.3.020 Kodi 18.6 is available.
After doing an online update, you may need to remove Kodi manually (menu - plugins - red button to remove plugins - extensions then select Kodi).
After this is done you can reinstall Kodi from the feed's / SpeedUP panel and this will install Kodi 18.6
Kodi 18.6 is available for all boxes that support Kodi (Ultimo4K, Duo4K, Uno4K SE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2).
