Kodi direct
redtangodancer
Kodi direct that came as a plugin with Black Hole 2.1.6.1 is causing each time green Screen.
Has it something to do with XBMC still in Gotham and not running Kodi yet?
Kodi direct is not included with BH 2.1.6 or 2.1.6.1 (or any other BH image), therefore you have either installed it directly, from a backup or are using a backup image created elsewhere.
Either way the problem is not with the image, it's with an external plugin.
