Hi, I have same problem with solo2 after recent update when I try to play video with Kodi 16.1 "Jarvis"
Thanks
Severall confusion:
- Your post is :
- OpenBH 04 images and Duo2 section
- Kodi Jarvis 16.1R2 is not implemented in OpenBH 04 ( so not yet supported in this image ).
Yes can confirm Kodi updated to 16.1 in duo2 0.4 obh image as well.....but doesent play films,just black screen and freezes box
The update to Kodi 16.1 was done by an online update and not by a telnet command
opkg install --force-reinstall /tmp/*.ipk
reboot
Uploaded file to box using ipk addon installer tested working ok with kodi 16.1. Now plays films
Thanks Black hole team
Good morning, how can I activate the subtitles? Now it does not work.
Thanks for listening.
Hello friend, yes I am Referring to kodi 16.1R2 subtitles, and using OpenBH 04.
With subssupport? What comes with the image and worked in kodi 15.2
Best regards
hi guys done this and it works but now kodi only runs in top left and corner at a reduced size! if there a fix?Install the attached file by telnet, reboot your STB, and reply if it solves your issue.
Howto:
Upload this file to your STB, by using an FTP tool to:
/tmp/ folder:
by telnet run this commands ( one by one ):
Code:opkg install --force-reinstall /tmp/*.ipk reboot
Go to plugins browser and push Kodi to start ( try it ).
This is important for us, so please, don´t forget to reply.
thanks in advance
