kodi launcher will not start
stevep
Hi,
Currently running Black Hole 3.0.2.F Kodi on vu solo 2 and when i start the kodi launcher the screen goes black and the solo 2 locks up.
I have a internal hdd mounted to sda1 and the .kodi folder is located in media/hdd.
I have checked home/root and there is no .kodi folder there.
I believe kodi is filling flash memory and causing the box to lock up when running kodi launcher.
Is there a kodi crash log to see whats causing this issue?
If anyone can advise how to resolve this it will be appreciated.
found this log in /var/volatile/tmp/kodi
15:45:38 T:1980076032 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:45:38 T:1980076032 NOTICE: -----------------------------------------------------------------------
15:45:38 T:1980076032 NOTICE: Starting Kodi (16.1-RC2 Git:2016-04-13-528f9f8-dirty). Platform: Linux MIPS 32-bit
15:45:38 T:1980076032 NOTICE: Using Release Kodi x32 build
15:45:38 T:1980076032 NOTICE: Kodi compiled Apr 13 2016 by GCC 4.9.2 for Linux MIPS 32-bit version 3.19.0 (201472)
15:45:38 T:1980076032 NOTICE: Running on Unknown Linux Distribution 0.0, kernel: Linux MIPS 32-bit version 3.13.5
15:45:38 T:1980076032 NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
15:45:38 T:1980076032 NOTICE: Host CPU: BCM7346B2 STB platform, 2 cores available
15:45:38 T:1980076032 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
15:45:38 T:1980076032 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
15:45:38 T:1980076032 NOTICE: special://masterprofile/ is mapped to: /media/hdd/.kodi/userdata
15:45:38 T:1980076032 NOTICE: special://home/ is mapped to: /media/hdd/.kodi
15:45:38 T:1980076032 NOTICE: special://temp/ is mapped to: /tmp/kodi
15:45:38 T:1980076032 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
15:45:38 T:1980076032 NOTICE: Local hostname: vusolo2
15:45:38 T:1980076032 NOTICE: Log File is located: /tmp/kodi/kodi.log
15:45:38 T:1980076032 WARNING: Unicode properties are not enabled in PCRE lib, support for national symbols may be limited!
15:45:38 T:1980076032 NOTICE: Consider installing PCRE lib version 8.10 or later with enabled Unicode properties and UTF-8 support. Your PCRE lib version: 8.36 2014-09-26
15:45:38 T:1980076032 NOTICE: load settings...
15:45:38 T:1980076032 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
15:45:38 T:1980076032 NOTICE: Change AESink retry count..
15:45:38 T:1980076032 NOTICE: AESink retry count - 1
15:45:38 T:1980076032 NOTICE: No Devices found - retry: 1
15:45:40 T:1980076032 NOTICE: Found 0 Lists of Devices
15:45:40 T:1980076032 NOTICE: Change AESink retry count..
15:45:40 T:1980076032 NOTICE: AESink retry count - 1
15:45:40 T:1980076032 NOTICE: No Devices found - retry: 1
15:45:41 T:1980076032 NOTICE: Found 0 Lists of Devices
15:45:41 T:1980076032 ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
15:45:41 T:1980076032 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:45:41 T:1980076032 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:45:41 T:1980076032 NOTICE: Default DVD Player: dvdplayer
15:45:41 T:1980076032 NOTICE: Default Video Player: dvdplayer
15:45:41 T:1980076032 NOTICE: Default Audio Player: paplayer
15:45:41 T:1980076032 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:45:41 T:1980076032 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:45:41 T:1980076032 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:45:41 T:1980076032 NOTICE: Loaded playercorefactory configuration
15:45:41 T:1980076032 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:45:41 T:1980076032 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:45:41 T:1979941968 NOTICE: Change AESink retry count..
14:45:41 T:1979941968 NOTICE: AESink retry count - 1
14:45:41 T:1979941968 NOTICE: No Devices found - retry: 1
14:45:43 T:1979941968 NOTICE: Found 0 Lists of Devices
14:45:44 T:1980076032 NOTICE: ADDONS: Using repository repository.xbmc.org
14:45:44 T:1980076032 NOTICE: InitWindowSystem: Using EGL Implementation: vuplus
14:45:44 T:1980076032 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
14:45:44 T:1980076032 NOTICE: Previous line repeats 2 times.
14:45:44 T:1980076032 NOTICE: Found (1280x720@50.000000) at 16, setting to RES_DESKTOP at 16
14:45:44 T:1980076032 NOTICE: Checking resolution 16
14:45:44 T:1980076032 NOTICE: GL_VENDOR = Broadcom
14:45:44 T:1980076032 NOTICE: GL_RENDERER = VideoCore IV HW (V3D-410)
14:45:44 T:1980076032 NOTICE: GL_VERSION = OpenGL ES 2.0
14:45:44 T:1980076032 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
14:45:44 T:1980076032 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_APPLE_rgb_422 GL_OES_packed_depth_stencil GL_EXT_debug_marker GL_EXT_multisampled_render_to_texture GL_EXT_texture_format_BGRA8888
14:45:46 T:1980076032 NOTICE: Running database version Addons20
14:45:48 T:1980076032 WARNING: CSkinInfo: failed to load skin settings
14:45:50 T:1980076032 WARNING: Previous line repeats 1 times.
14:45:50 T:1980076032 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
14:45:50 T:1980076032 NOTICE: ActiveAE DSP - starting
14:45:50 T:1980076032 NOTICE: initialize done
14:45:50 T:1980076032 NOTICE: Running the application...
14:45:52 T:1980076032 NOTICE: starting zeroconf publishing
14:45:52 T:1980076032 NOTICE: starting upnp client
14:45:52 T:1632367696 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
14:45:52 T:1632367696 NOTICE: UDP: Listening on port 9777
14:45:52 T:1980076032 WARNING: no keymap support (requires /dev/tty0 - CONFIG_VT)
14:45:57 T:1980076032 ERROR: Unable to activate the previous window
14:46:09 T:1980076032 NOTICE: Storing total System Uptime
14:46:09 T:1980076032 NOTICE: Saving settings
14:46:09 T:1980076032 NOTICE: stop all
14:46:09 T:1674310736 ERROR: CAddonInstallJob[metadata.album.universal]: failed to download special://home/addons/packages/metadata.album.universal-2.7.0.zip
14:46:10 T:1980076032 NOTICE: stop player
14:46:10 T:1980076032 NOTICE: ES: Stopping event server
14:46:10 T:1980076032 NOTICE: stopping upnp
14:46:10 T:1980076032 NOTICE: stopping zeroconf publishing
14:46:11 T:1632367696 NOTICE: ES: UDP Event server stopped
14:46:11 T:1980076032 NOTICE: stop sap announcement listener
14:46:11 T:1980076032 NOTICE: clean cached files!
14:46:11 T:1980076032 NOTICE: unload skin
if anyone can help troubleshoot.
