Kodi resolution
SLR_Vision39
Hi,
I have installed the latest Kodi on VU+ Duo2 with OpenBH 4.1.024 build.
When I open Kodi, it only allow me to select 1280x720p (sbs or tab) resolution.
My TV is able to do 1080p, the VU+ is configured for 1920x1024
How can I change this resolution to 1080p ?
Thanks
Hi,
Thanks
It is not possible ... this is just an UI resolution and not the ability that kodi can´t run other high media resolutions ( for example 1920x1080 ).
I've tried kodi 16.3 on BH 3.05 and it sucks. Its so slow you can mow the lawn for 5 minutes and return to find nothing ha happend. Why?
If you use kodi, quite often, as I do, I use Open Black Hole 4.1, which runs Kodi 17.6.
I'm now waiting for Kodi 18, Leia, to be completed, and installed on a new Open Black Hole image.
