Kodi wont launch
Fac51
BH 3.0.2G
Solo2 box
Plugin browser > Kodi Launcher > Black Screen > returns to Plugin Browser
Any ideas what is causing this?
Plug of your usb if you are using one for kodi, format your usb then mount it again media/hdd and launch kodi.
not working this metode on my duo 2 :(
mount usb like usb like HDD mapes media/hdd but not launch kodi.
my duo 2 recording perfekt and al files is map media/hdd .
I'm sorry for you mate this strange thing happened to me too a month ago or so and that what i did.Yes 2.1.7 was one if not the best versions of blackhole,but now we go to OE3.
I have same issue. Kodi wont launch from plugin browser. I add new formated usb stick. I mounted as /media/hdd. What should I try??
Thank you.
Does vu+ zero & 4k could handles plugin kodi i mean if the tutto can support kodi or not and what's kind between vu+ can support it thx??
i just found this information about kodi and vu+
Kodi:
The Zero 4K (as with all Vu+ 4K receivers), supports Kodi, which means you have access to a huge array of multimedia addons, video, movie, music and radio streaming from the internet.
The original VU+ Zero is an older model, compare to the newer 4K versions, and wasn't designed to be as good as the Duo2, or Solo2, more as a second receiver.
If you visit the VU+ website, and check the product specifications, you'll understand which models can handle the latest Kodi.
Scroll to the bottom, of the linked page, for the chart:
http://vuplus.com/sub/sub0102.php
