kodi
yummer
BH Lover
Installed latest vu duo2 xbmc image and must say how great and speedy and responsive it is on our stb's. Just wondering if anyone is working on the latest Kodi helix 14.1 stable for our boxes? Also is there no way to integrate the live TV PVR function from within xbmc like I do on my htpc using the PVR vu+ back end?
Hi,
It's in spanish, but you can easily understand what should be done.
Hello,
A video in English:
hi,
Unfortunately I cannot test xbmc image on my duo, I'm using black hole image, which is great, please before testing any image on your Vu+, please do make a full backup so as to re-flash your receiver and get your box set as it was before the tests. how to make personal and full backup it's for black hole image, I do not know if it is the same thing for xbmc image!!!
It seams that black hole team is developing xbmc addon for blackhole HERE
you can even find a Blackhole image including xbmc launcher Here (
http://www.sat-universe.com/showthread.php?t=279113
). I have no idea if the live tv pvr function is integrated in that image, i did not test it on my box, so i cannot say if it works. The description shows HasBahCa IPTV Player (English version) pluging, is it an iptv pluging? It's up to you to find out. Good luck my friend
Hi, I've been asking the same question re pvr and Kodi. My vu duo2 box came with xbmc Gotham already installed, is this the version you have? Or a later one? If later, could you tell me the process/image link you used to install? Any help appreciated
Actually, no PVR clients avaiable
