Kodidirect_3.1
Matrix10
1.install plugin Kodidirect
2.Install all updates ignore errors
3.And as the last replace plugin.py in /usr/lib/enigma2/python/Plugins/Extensions/KodiDirect/
(After each Kodidirect update is necessary to replace plugin.py ,but not after addons update )
4.reboot.
if you cannot play with play try with hlsplayer
This mod plugin Kodidirect (does not support f4mTester no python-pycurl /breaks BH image coding )
Use new plugin.py next post
Hi all.
How are you! Happy new year.
I have a question, can I install this plugin in my vu+ ultimo with BH 3.0.2 image.?
Tahnk you for answer.
Sent from my ONE A2003 using Tapatalk
Buenas noches.
Yo también quisiera saber si se puede instalar KODIDIRECT en un VU+ ZERO con blackhole 3.0.3 y así poder poner PELISALACARTA.
