Lan 2
Pessimoelemento
Good evening. I assume, because I am not sure, that after updating to version 3.1.0. G Vu + solo 4k, I am connected to the LAN 2. All communication protocols with the decoder are not working (telnet, ftp ....) so it is not possible to update for example, the channel list. Instead, the internet connection to the outside works. Possible solution? Thank you
Pessimoelemento
Thank you. VPN was active. I deactivated it and the Lan 2 connection is gone. But the ftp and telnet protocols still don't work even after full reboot.
p.rodrigues
I updated now the Uno 4K SE if, everything ok.
