language dissapears
kalliffen
Hii..
I installed
black hole Vu+Duo 1.7.2 (media-tree)
and so far it looks pretty nice, only thing i have problems with is that my 2 year old son like to turn off the power at the wall socket, and after plugin it has lost the settings for language.
i have manually set the lanuage on every channel ( can't figure out if it can be done automaticly) that needs it like Boomerang, Cartoon network etc ( im danish) and this takes quit some time, so if there is a way to keep it it would be highly appriciated.
cheers
Hii..
I installed
cheers
After U do the language settings, try the followings:-
1- save U'r settings , using Software managements!
2- Make a settings Backup , using BH Personal Backup!
It may work 4U this way!
Have Fun w/BH
a911
