LAPTOP tuner - VU+ Ultimo
mr rx
Hi Guys,
I am looking for a bit of advice.
I would like to capture a continuous stream from VU box. I guess i need a capture card laptop side and run composite cables to VU+ Ultimo?
I do not want to stream a single channel, I am looking for a continuous capture so any advice most welcome :)
Thank you
Hi Guys,
Thank you
You can try to use an acquisition card and use, as you write, the composite out of your box to acquire the treams ...
Hi mate,
do you know of one that will work with VLC for streaming? Or would it have to go through something like AmaRec and Adobe flash?
thanks
