LCD PROBLEM
herts2201
I bought VU+ DOU recently and installed latest blackhole image. Everything work perfectly apart from no channel info come on the lcd screen of VU+. if i go in the menu it is written on the lcd screen or if do scan it also comes up in the lcd screen but when i change the channel, channel change perfectly but it does not showed in the lcd screen of VU+. Instead there is written " NO SERVICE FOUND" on the lcd screen. unless i press menu on the remote and it showed " menu" on the lcd screen.
Can somebody help me to solve this problem. thanks
I did try to remove or uninstall the LCD PICONS. but when i go to ADDONS i find only ***** entry, no other entry. I could not find LCD PICONS in plugins either. Can you please tell me how to uninstall these. I find LCDPICONS and VFDPICONS folder when i ftp to my box. do I need to remove these folder or any other way to uninstall. Many thanks
What? Are you reading our Board rules?
WE DON'T SUPPORT ANY KIND OF ILLEGAL SOFTWARE LIKE YOU MENTION.
User banned for 1 week.
Hi.
I was having the same problem no service written on my vu+ dou lcd screen. I read this post and specially the post where user has been BANNED for 1 week. The guy is asking for problem with LCDPICCONS and how to remove them , he is not asking for support for any illegal software. he has just mention the name of the file or folder( ). Angelofsky1980 , you should read and more important u should understand before u BANNED somebody. I do not wanted to write anything but your comments make me write something. I advise you to consult somebody before you banned any user on their questions. BY USING WORD CRIME, IS NOT A CRIME AND THE PERSON WHO USE THIS WORD IS NOT A CRIMINAL. IF SO THEN EVERYBODY IN THIS WORLD IS CRIMINAL.
Thanks
hi
i also have this problem with the vu+ duo, my box only displays the programe that is on (eg eastenders) only after i press the epg button? and does not change when the channel is changed? any help would be great thanks
Hi there,
I see long discussion here but no answer to the question :(
I just messed with picons yesterday on my VU+DUO2 and now have unreadable LCD screen.
How can I remove badly installed picons?
Any help appreciated.
